Old 03-10-2018, 05:25 PM   #239 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Fiberglass sounds like a lot of work. Can't you just wrap it with vinyl? Maybe two layers?
Without fiberglass, the foam might be strong enough with resin; without resin, definitely not. It punctures quite easily, which a vinyl wrap wouldn't really protect against.
With two layers of fiberglass, 1/2" foamboard is as strong as 1/4" aluminum sheet, according to an engineer I talked with yesterday (who is building a 240-mph motorcycle streamliner to take to Bonneville and skinning it with foam/fiberglass--it's quite a sight, but with no body yet).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
