Old 03-12-2018, 10:47 PM   #17 (permalink)
ProDigit
Originally Posted by ksa8907 View Post
I would say thats a very poor way to use the vehicle. The gas engine should never be used to "charge" the battery. Why have a battery then? The idea is you have a battery that you charge from the grid which is cheaper per unit of energy that gasoline. Then, switch over to gas if you need it.
In charge sustain, CS mode, I consistently get about 37 to 39 mpg with windy, 15f to 50f weather and winter gas.
That's how the volt operates. It's engine always charges the battery, while the battery powers the electric motors.
On the volt you don't have the choice to drive the gasoline engine directly.
And I think that's the question of this thread,
How much does driving the gasoline engine give on MPG.
