I bought mine new, 180k in it, a good portion of its life was driven pretty aggressively when I was younger and dumber, so far it’s had two alternators (one for over charging under warranty, second not charging enough I did myself a couple years ago it was undercharging) I had one coil go bad, so I replaced them all, A upper plenum gasket was bad causing a minor lean misfire until car went into closed loop, and I had a rear main seal done under the extended warranty the car had( it was a very minor leak).
I’ve done front brakes twice I got 75k out of first set with more left I could of gotten out of them, second set lasted almost another 100k, other than the rear hatch leak they are known for( fixed with Toyota fipg silicone) I’ve just changed fluids and tires.
