Example of pumping losses.
Just grabbing the first numbers I can find, a chevy 305 at idle:
assuming: 75 cubic feet of air per minute at 20 inches of vacuum
(75 cfm) = 2160 cubic inches per second
imagining a 1" square piston in a suitable "cylinder", it can lift 20 lbs, 2160 inches in one second. I figure that is about 6.54 horsepower in pumping losses at idle across the throttle plate. (1 hp = 550 foot*lbs/second)
