Whipped up a simple little through hole board to drive the low sides of two 600A IGBT half bridge modules. Based on the ACNW3190 driver chip.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
