Originally Posted by Angel And The Wolf
There should be a software program that can coordinate continuously moving slugs of traffic citywide without stops,save the first one at every entry into the grid. Speeds could be set at the optimum for each set of blocks between successive lights (maybe 35 at some, maybe 27 at others.)
The problem is that unless you have a nice, regular grid, you can only do it on some streets. Do it on street A, and it's not likely that intersecting streets B, C, & D will match timings. And then streets W, X, Y, and Z that intersect with them have to be considered. Then you have to consider different traffic flows at different times of day, whether there are cars waiting in the left turn lane...
