Old 03-17-2018, 04:55 PM   #5 (permalink)
redpoint5
90 day: 51.16 mpg (US)
I hadn't heard of HIR until you mentioned it. Seems they aren't made in the H7 size, otherwise I'd look into that.
I'll probably just throw a spare ballast back into the Prius and keep running these cheapo HIDs till I run out of spares. Hopefully in 6 years good LED replacements will be available.
I'm wondering if the 35 watt rating of the HIDs means to the bulb, with 12 watts lost to the ballast? Now I'm curious if even expensive HID units draw less power. Perhaps I can measure the stock HIDs in the Acura to answer this.
