Old 03-18-2018, 12:04 AM   #37 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by ProDigit View Post
Because an ev doesn't have drivetrain and gearing losses.
Whatever the motor produces, is pretty much whatever is at the wheels,minus rolling resistance (like from deflated tires).
A 4 stroke of 150HP usually only gives 135HPmax at the wheels, times the gear ratio.
Eg: if you have an overdrive gear ratio of 0,97:1 as 4th gear, being closest to a direction drive, and 134HP at the wheels with a direction drive, your car is only getting the performance of a 130HP at best. In 6th gear, if your gear ratio is 0.75:1, you're essentially only getting 97.5 HP in final gear, from a car which engine gives 150HP.
Yes I understand the concept of what you mean as I'm engineering (gear reduction and efficiency), but your not gonna need more than 20-30 hp to maintain 70. Horsepower to overcome drag at 80 mph would be around 40% more which still would only be like 1/3 throttle.
Also EVs still have gear loss its just minimized since they only have a final drive system forgoing the transmission unit. So no free cake here.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
