Old 03-20-2018, 08:05 AM   #1 (permalink)
Hic
VW 1.6TD Engine Off Coasting
The service manual for my MK2 1.6TD VW states that damage may occur if towing on the drive wheels at speeds greater than 80kph/50mph. Does this mean engine off coasting above 80kph is harmful for the transmission? I thought only automatic transmissions see damage from engine off coasting. Is this transmission in particular incompatible with high speed engine off coasting? Or is engine off coasting normally not used at these speeds? I've pulsed and glided regularly between 70~110kph on this car for almost 2 years now...should I be concerned about transmission damage?
