Old 03-20-2018, 10:56 AM   #15 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I wonder why the Volt gets "such low" highway mpg. Did GM go with a relatively inefficient powerplant? Is it the tires? How efficient is the 1.4? I seem to recall reading that the related hybrids (Malibu?) had higher combined ratings on gasoline.
Thermal efficiency is only 10% less than the Prius (35 vs 38.5). For the most part its because:
Drag area is: 23.7 x 0.285 - 6.7545sqft
Prius DA: 23.4 x 0.25 - 5.85sqft.
So the Volt has on top of 10% worse thermal efficiency, it has 15.5% more drag, and weighs 24.6% more (3790 vs 3042) and required wider tires to drive like a normal car etc...
Big bummer with the V1 Volt is it also recommends Premium fuel while the Prius will run on regular.
So its like its a huge car but has the same interior space as the prius but one seat less.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
California98Civic (03-20-2018)
