Old 03-20-2018, 09:03 PM   #4 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Originally Posted by jakobnev View Post
Above certain speeds the Prius needs to run the engine to prevent MG1 from spinning too fast. Adding a kill switch might damage your vehicle.
True, but that speed is above 85 MPH according to the specs I've read. I've EOC at 75 MPH before without issue.
Your easiest solution might be to fool the temps (search online for how to do that) and let the engine turn off at the top of hills by remaining under the 44ish MPH switchover point, and then shift to N allowing the vehicle to gain speed. No regen in N though, so beware of that tradeoff.
I've got a plug-in Prius, so I can cruise up to about 60 MPH before the engine kicks on, and can shift to N if I need to coast at faster speeds while leaving the engine off.
Not sure what an injector kill would do. Might really anger the Prius, but give it a try for science sake!
