Old 03-24-2018, 01:07 AM   #34 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Mount the , for lack of better term wing /downforce device to the suspension to apply downforce directly . This allows for a softer springs -> better handling.
Im thinking somekind of sail on the bottom of the car that when you getting excess of airflow underneath of your air dam indicating lift, the airflow would push on the cell pushing and turn pushing a lever that would add pitch/AOA to the front wing. Kind of like a self deploying countermeasure. kind of like the roof Flaps in NASCAR but in a whole different context.
Mechanical force under the car versus the force on the wing above the car maybe too far away from each other. this can be solved with two servos. the first Servo can be the smallest one you can find you're only interested in the potentiometer and the ability to add a linkage. the second Servo would control the wing receiving its commands from the first servo having its potentiometer wired in place of the second servo. Considered an electro mechanical leverage.
another potential means of controlling this undesired vertical movement is with another pair of gyros to control the front wing and rear wing independently
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
