Old 03-27-2018, 11:24 AM   #1 (permalink)
InitialCivic
speed vs rpm scangauge?
Greetings Ive recently picked up a scangauge and have been monitoring my mpg. It appears to favor higher speeds over a lower rpm, example being i could be going 18mph at 1100rpm vs 22mph at 1400rpm and it'll always read the higher mpg for faster speed. Why is that? I assumed the lowest rpm it can go would yield best mpg. Same when it kicks into 5th gear at 35ish and has the rpms really low, it always reads lower mpg than if i was going faster. Sorry if this is a dumb question im new to all this. veichle if it matters is an 07 civic thanks!
