My assessment is based on both coastdown(on points where I usually EOC) and instant MPG measured at 55mph...
I completed the mod at work so I tested it on my commute home, and found that in places I usually coast in, I’m arrivig st the other end at a slightly slower speed... for instance there’s a section where I arrive st the top of a slight downhill at around 40mph and at the end, almost a mile later I usually arrive at 38-40mph depending on surface water and temperature... the night I tested the mod, I arrived at 34mph...
Additionally, I found that my instant MPG at 55mph(with severe misfire and being in open loop) dropped from ~31-32 to around 27-28... with the engine making so little power, the extra drag is plainly evident...
HOWEVER...
I made a couple mistakes during construction that I addressed...
1. I put the leading edge of the Kamm on the sealant seam at the top of the back glass, making a 8-10mm lip for air to jump
2. I used metal strapping material taped to the trailing edge(underside) to keep the trailing edge straight but as low as I had the sides pulled down it bulged up in the center and pushed the center up to a flatter angle than I wanted...
I accidentally tore the thing off backing up at around 20mph and when I put it back on I addressed the above flaws(but I didn’t have/lost the metal strip) so the center of the Kamm now saga, but only when the car is stopped... it lifts above around 35mph, to be flat across its width
My current Ecotec project...
My last Ecotec project...
