Thread: iDuino MPGuino
Old 08-27-2008, 03:21 PM   #58 (permalink)
Axaday
Originally Posted by cmags View Post
Sounds like you nailed it. If the LED started blinking right after bending it (temporarily) and then touching up the solder points, it sounds like you may have had just a bad LED connection, because the program did actually load properly. Either way, sounds like you're good to go forward and load up the MPGuino .pde. Did you build the other circuitry yet?
No, but I expect to start on it within the hour.
I looked at Radio Shack for a disconnect that would look nice and I found nothing. Then my dad suggested using telephone jacks. A phone jack has 4 24 guage wires and seems perfect, but the rainbow wire I HAVE doesn't look like it will fit. Does anyone know why I shouldn't just strip a telephone line to serve as the 4 wires initially coming to the unit?
Edit - Actually, I see that the phone cord I was planning to use is 26 gauge. Will that be good enough for what will be running ground, power, VSS, and injector?
