I believe you are right. I moved both engines behind the driver, placed an idler shaft behind them, and put a sprocket on the shaft for each to drive. Then added a third sprocket to run the final drive chain to a single rear wheel.(Yes, it's now a reverse trike - see permalink 8 in this thread). The Idler should provide the direct mechanical coupling you speak of.
