Old 04-02-2018, 06:56 PM   #566 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Originally Posted by Phinzor View Post
Hey Bill what kind of MPG do you think we are going to get in our conversions. I think my mustang will weigh a bit less than the prius did originally but way less aerodynamic. Ive driven it around the yard a couple times but not on the street yet.
What have you done with all the airbags? I removed all the side airbags and cut and covered the wires for them but now im getting a pesky P3107- 214 Airbag ECU Communication Circuit Malfunction code that triggers the big yellow triangle and keeps beeping "check hybrid system"
Good questions! The Firebrid will be heavier than the original Prius v due to the extra weight of the convertible parts. Aerodynamics will be much worse, but the mpg's compared to the old Firebird powertrain will be double at least!
I am still deciding whether to keep the steering wheel airbag. The others have no place to mount (especially with the top down.) I WILL be adding a simple roll bar with base reinforcements behind the front seats to hold the shoulder belts I will be adding. (See earlier discussion some pages back.) The diagonal bruise across my chest from my recent accident has driven home the point that the shoulder belts are a must-have even though the original car did not have them.
The wiring for the airbags that are no longer there will get shunted with a resistor at the connector.
Bill the Engineer
The Following User Says Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020)
