Originally Posted by Ecky
I've been playing with doing this same swap, on paper. If I go through it, it will be an "all of the above" type deal.
Even with an aftermarket final drive and the tallest 5th/6th available, the 2.0/2.4 will still be spinning faster (with the engine's factory tire size) than the 1.0L in the Insight at the same speed. Nevermind with smaller wheels.
The 3.4 FD with the .647 6th gear puts the car at 2307 RPM at 70MPH not bad.
2350 with the 0.659 & the 3.4FD
With the 4.058 FD and the tsx 6th/accord 5th 2803 at 70mph
4.058 FD and the +12 Si 2752
With the tsx 6th and the stock rsx FD of 4.38 puts you at 3022
Im currently at 3318. (with my slightly larger tires) :vomit:
