Old 04-04-2018, 05:38 PM   #10 (permalink)
Phinzor
^ Don't even notice the extra body height from that angle.
I'd chop a coil or so off the Prius springs.
Larger tires may fill the wheel well better, but they'll lift the car higher too.
Thats what i will do then. the stock mustang tire is only 1.1 inches taller than the prius tire so its not worth going to a bigger size. I will chop the springs and probably add 1 inch wheel spacers to the rear to bring the tires out flush with the fenders. I plan on keeping the Prius wheels on there to confuse people as I drive by in EV mode
