Old 04-07-2018, 06:21 AM   #1 (permalink)
Angel And The Wolf
Two Stock CB750 engines, One Transmission?
Will the Honda CB750 transmission handle double the power without breaking?
The two engines being phased 90 degrees apart, would be putting out one single power pulse every 90 degrees, rather than one double pulse every 180 degrees as they would if they were phased 0 degrees apart, therefor each pulse would be no stronger than a pulse from a single engine, not twice as strong, as in two engines firing in sync.
The pulses would just be coming twice as often.
Would the transmission see this the same stress as with just one engine, or would the transmission need to be beefed up?
Name:	Twin Hondas Firing Order.jpg
