Originally Posted by mazdamx640
What engine does it have 4.6 or 5.4? I'm assuming these are just about the same as a f150 if so 20 mpgs should be easily attainable with a few mods. My 99 f150 gained about 2 mpgs from switching to an electric fan so that's a good start. I also recommend a lawn edging air damn extension, synthetic fluids in diffs and transfercase, upper grill block and 12 hole injectors
5.4 unfortunately. Keep in mind the Expedition is a good 1000+ lbs heavier than an f150. And a lot of f150's have a taller rear end ratio.
