Originally Posted by elhigh
...... I generally think taller/narrower is the way to go, other factors being equal.
Ah ..... Mmmmm ...... not exactly.
The data seems to point to wider and taller being better. See my web page on the subject:
Barry's Tire tech - Rolling Resistance and Fuel Economy
The best guess as to why that is is that the increase in load carrying capacity causes a greater reduction in RR than the effect the smaller volume of material.
But, again, a tire size change is so small a change if everything else is equal, that it's hardly worth mentioning! Differences in the make and model of tire are SOOOO much larger.
