Old 04-10-2018, 06:42 PM   #7 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
Well I should put up more pics. I have the motor all mounted and have tried the battery but there is a problem. I need to go back and re-do the main battery connection because it is trippin off with anything more than the slightest throttle or any load on the wheel. Basically I can lift of the rear tire, give it 1/16 throttle and it will spin up but any load tips it all off and requires the battery to be unplugged and plugged to reset. It might be a problem with the controller or BMS but I don't trust the connection I made up. I'm going to switch to a crimp style instead of the soldier.
Good thing is it is much quieter than I expected and isn't that much different to pedal without the assist. That poor bottom bracket that came with the bike is completely replaced with a cartridge style in the kit.
The Following User Says Thank You to Hersbird For This Useful Post:
slowmover (04-10-2018)
