Old 04-11-2018, 12:54 AM   #8 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
Ugg, I cant figure it out. Tried a BMS reset by charging through the discharge line on the battery. Re-did the connections. Put a voltage tester inline with the battery to the motor and to me it seems the battery's BMS is cutting the power. The line reads a good 65 volts but then try the throttle with load and it trips down to 1.9 volts. Unplug and replug the battery and it's back to 65v coming from the battery. Tomorrow I'll try just running it off the charger, no battery at all and see what happens. Everyone seems to suspect the simple stock controller that came with the motor kit but I don't see how that's tripping the battery voltage in the main line directly from the battery. The batter is the most expensive thing and hardest to ship by far so I hope it's not that. I'm waiting to hear more from Luna cycle to see what they want to do as it's all brand new and under warranty.
I kind of wanted a better controller anyway but think the stock one should work before moving on.
