So it has to be the controller. Running the 5 amp charger directly to the controller using no battery at all does the same thing but now will self re-set. The stock controller should be good for 40 amps continuous but it tripping somewhere below 5 amps. Now if I could get a response from Luna. I had wanted to buy an upgraded controller anyway, but they don't give you a break compared to the stock one so I figured I would have a stock working one as a backup if I bought a better one. They charge $50 for the basic stock one as a replacement but only knock $10 off if you upgrade when you order. Hopefully they will just send me a new stock one so I can get this thing on the road. I have a camping trip planned for the 20th-24th and 4000+ acres of state land open to this form of bike to use it on.
