If I can fit it into the trunk, I'm thinking that will be the best location, otherwise the rear seat lower cushion is similarly sized, but I really didn't want to have to build a fire wall.
I believe the dam is 2 inches from the ground, I need to figure out my loaded ride height for the trip before I finalize that aspect. The rear of the car appears to sag unloaded, so I opted to leave it low; easier and cleaner to remove material than add.
I'm considering dragging my 2900 lbs roadster behind, it seems the problem with these older aluminum head diesels is cooling. I need to research more about the under tray/ splitter under the front and utilize heat extraction benefits to make the radiators as efficient as possible as opposed to pure drag reduction.
