Originally Posted by Grinder74
Are you sure you can change the H/L lever at speed? It would be great if you can.
Yes, but some steps are so close together (3rd High [6.37] to 4th low [6.14], and 5th low [5.26] to 4th high [5.25]) that it is quicker to skip them. I've come up with seven gears that may be the quickest acceleration run (See the diagram in post number 2, this thread)
