Old 04-19-2018, 09:27 AM   #25 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Originally Posted by interestingstuff View Post
While you're swapping out the bulbs... you can also swap out the cargo / trunk light with a drop-in replacement that has a built-in switch so you can turn it off and keep the hatch open when needed.
More info here: https://www.fitfreak.net/forums/fit-...ll-w-pics.html
Unfortunately the pics are gone from that thread, but they have the part numbers for the replacements.
Another thing you can look at is swapping out the battery for a bigger one. Yep, it will add a little weight but I've found it to be effective. (I have the GE not the GD model.) I've run down the standard battery several times in the past. I upgraded to a better battery and have never had that problem again.
I've done all of those. LED marker lights front and rear, brake lights, dome lights, cargo light, cargo light switch. Upgraded battery. No LEDs in the turn signal because they hyper-flash. Not that they're on enough of the time to be a big deal.
Mine (2nd gen 2009) is made in Suzuka, Japan.
