Thread: Steering locked
Old 04-19-2018, 05:24 PM   #2 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Hi larrybuck,
With a steering wheel puller, I believe you can pull the steering wheel, and the locking disk is just under the turn signal cam, oh there might be the clock spring in there too. The disk is held on with a split ring and there is a big spring behind the disk. You can pry out the split ring, but the spring may shoot the disk out at your face, so beware.
-mort
The Following 2 Users Say Thank You to mort For This Useful Post:
larrybuck (04-20-2018), Xist (04-19-2018)
