Originally Posted by cRiPpLe_rOoStEr
How can we explain that? Or maybe we shouldn't even try to do so, and you might just feel tempted to add a water injection system to the Twingo
i have definitely thought about that
probably the swapped engine will have mildly high compression, a small turbocharger to increase efficiency and a custom megasquirt ECU
(well, my lada had a non-crossflow, swirl-type combustion chamber (for better starting, even atomization and burning of even crappier fuel, but it raises piston temperature on higher revs so it gave really noticeable good results in the rain)
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
