Originally Posted by mpg_numbers_guy
Except for the Insight all of those seem majorly overpriced. #1 should be $2000-$2500, #2 should be similar to the Insight, and #4 should be $3500-$4500.
Out of those four I'd go with the Insight, but honestly if I was shopping I'd keep looking for better alternatives.
Good luck to you though, hopefully you find a car that works out great for you!
Thanks, that is quite helpful. I do like the Insight quite a bit.
