Originally Posted by Angel And The Wolf
Think I'd like to attach the VW front axle unit to a home made narrowed three wheel version of an Atom exoframe.
Of course, with a lighter, far less powerful engine, my tube frame could be smaller diameter, or lighter gauge tubing.
I want to sit centered, so the steering column will have to have a three gear set to transfer the input to the left to line up with the steering box on the VW unit.
This solution would also allow me to custom tune the steering ratio for quicker
(less turns lock-to-lock, preferably 1/2 turn lock-to-lock, if the front end is light enough), and using non-circular gears, I could limit the quicker steering progressively towards left lock and right lock, without it being so sensitive to minor input at dead center.
