Using my Ultra Gauge, I have taken some fuel flow rates at a selection of idle speeds.
Engine Fuel MAP
Speed Flow
(rpm) (G/hr) (psi)
750 0.14 3.8
1000 0.17 3.48
1250 0.21 3.34
1500 0.23 3.05
1750 0.29 3.19
2000 0.31 3.19
As my car has a MAP sensor with no MAF, the Ultra Gauge appears to assign a VE of 75% across the whole load/speed range and then calculates the air flow based on the manifold air density and this assumed VE. The fuel flow is then proportional to the air flow.
I am curious if any North American owners have measured idle fuel flows as their cars have a MAF sensor and thus the fuel numbers should be more accurate?
