Old 04-26-2018, 12:12 PM   #2 (permalink)
cRiPpLe_rOoStEr
Originally Posted by hat_man View Post
I'm not really sure exactly what vacuum's function is in an engine either.
Apart from some older ignition systems that relied on vacuum to variate the timing, I don't remind any other utility for it in the engine. Well, on the other hand it does work as a power source for brake servos and other auxiliary systems...
IIRC low vacuum is the engine running more efficiently right?
Low vacuum is a result of fewer restrictions at the intake, such as a wide-open throttle valve, thus the engine in fact runs more efficient because it has to do fewer work to intake a given amount of air (leading to smaller "pumping losses").
hat_man (04-26-2018)
