Old 04-26-2018, 06:14 PM   #3164 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
The resolver ground wire is just an optional thing if you have the resolver cable shielded. You send the shield to ground. It works fine though to just twist ex/!ex, and then twist sin/!sin, and twist cos/!cos.
Also, what I did was in the middle of the resolver cable just have a bunch of insulated quick disconnects (the male/female spades) which makes it easy that way to swap them if necessary too.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
wootwootman (04-29-2018)
