Old 04-27-2018, 11:02 PM   #11 (permalink)
cRiPpLe_rOoStEr
Originally Posted by mpg_numbers_guy View Post
The lowest speed in the highest gear generally nets the highest FE....what's with trying to complicate things with a vacuum gauge?
Decreasing the pumping losses in order to allow the engine to operate more efficiently not just due to the RPM range but also due to the fewer pumping losses. It makes some actual sense.
