Originally Posted by MPaulHolmes
Try "run-pi-test2". This works better, and I think it's implemented in what you have. if it's not I can implement it. It basically lets you get a visual inspection of the convergence rather than letting the computer see if it's converging.
Hi Paul,
run-pi-test2 is not a valid command for my firmware.
Can you send me a link ... and is it time for an off-site backup?
When I ran
run-pi-test
it ran the first time for about 30 minutes and the battery on the controller died. No results
Second time, with a different 12V accessory battery ... after 30 minutes ... it had gotten to up ratio 67 by the time I pressed enter and stopped it.
So I tried just running it with the parameters from the Siemens motor. And the motor did not respond to the throttle signal. The output of the AC controller did not seem to go up. I'll post later tonight with the logs. It's sort of strange.
More to come later tonight
