Originally Posted by MPaulHolmes
thingstodo, did you get the updated software I sent a couple weeks ago (april 11)? It's the updated code, but with the through-hole board incorporated into it.
I read the email ... but didn't download or install the firmware or source code
I will do that! Likely tomorrow.
Still a bit confused by why the controller did not use the old settings to try starting the Polaris motor though. All I should need to do is power up and hit the throttle ... right? The encoder pulses rise to 3.9 VDC and fall to 0.2VDC .. that should be good for a 5V input?
I didn't get the logs loaded last night. Will get that part done tonight - hopefully
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
