Old 04-30-2018, 12:59 PM   #3212 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
thingstodo, did you get the updated software I sent a couple weeks ago (april 11)? It's the updated code, but with the through-hole board incorporated into it.
I read the email ... but didn't download or install the firmware or source code
I will do that! Likely tomorrow.
Still a bit confused by why the controller did not use the old settings to try starting the Polaris motor though. All I should need to do is power up and hit the throttle ... right? The encoder pulses rise to 3.9 VDC and fall to 0.2VDC .. that should be good for a 5V input?
I didn't get the logs loaded last night. Will get that part done tonight - hopefully
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (04-30-2018)
