Old 04-30-2018, 02:06 PM   #3172 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
Could you do:
stream-poscnt 1
data-stream-period 100
then slowly turn the motor shaft by hand to see if you get smoothly changing position. That will show that the encoder is working properly.
I can do that! I could not remember which variable to turn on to check on the encoder. The mechanical rpm seems to be a random number generator when the output of the controller is not on
That will likely happen tonight as well
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
