Originally Posted by samwichse
Fresh batteries might make a world of difference, if the existing SLAs are high IR and sagging very low under any kind of strain. Do you have a newer pack you could test-swap in?
I was using 3 over-sized(20ah), healthy SLAs. Even so, I'll check the draw and for voltage sag. Not likely at the batteries, but could be from undersized wiring.
