Originally Posted by California98Civic
I have thought of that, but my preference was to inset maybe a long strip of black coroplast that would also compress by not stick. Maybe I could use the coroplast and "face it" with a bead of black caulk, first dressing the trim pieces with linseed oil to prevent adhesion to anything other than the coroplast. Hmmm....
Aren't some caulks relatively easy to just peel off? Can't imagine it doing anything to your car.
Originally Posted by Vman455
It's important to keep in mind that the template is an idealized form; it isn't the only way to do things, and most real-world, low-drag cars do not adhere to it. Aerodynamics are too complex to distill into a single shape and say that's the only way to do it.
Example: the GM EV1 is drastically sub-template, yet achieved a very low Cd. And, with a tail extension that was also sub-template, set a land speed record for electric cars with an estimated Cd .15.
Similarly, the Merkur XR4/Ford Sierra formed the basis for Ford's Probe III, which didn't change the body shape or double-decker spoiler. It achieved Cd .23:
Testing would be the only way to go...but testing requires fuel and will ruin my tank average. xP
Originally Posted by elhigh
I like the front air dam. I'm seconding the other guys that mentioned adding washers to spread the stress over a wider area.
The self tapping screws we used had washers that came with them.
