Old 05-01-2018, 12:52 AM   #3174 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by thingstodo View Post
I can do that! I could not remember which variable to turn on to check on the encoder. The mechanical rpm seems to be a random number generator when the output of the controller is not on
That will likely happen tonight as well
Results for April 28, 29, 30
I attached the raw logs. I typed a few notes while hyperterm was capturing. see if they make sense. I'll go through them a bit more tomorrow night, but I found out I have training tomorrow night so I only have about an hour.
Didn't get the firmware loaded in.
stream-poscnt 1 is a not a valid command, so I guess I need to load the firmware to get that command.
At the end of the April 30 log I rotated the wheels by hand. First back and forth several times. Lastly in the same direction for several seconds and it looks like I seem to have gotten a consistent direction and speed.
I think the encoder signal is coming through OK.
I still can't figure out why the controller is not putting out current when I move the throttle signal. Weird.
The base config from Andrew's siemens AC motor is in the logs in a couple of places. It should at least TRY to rotate! SIGH!
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
