Old 05-01-2018, 07:48 PM   #3175 (permalink)
wootwootman
Hmmm I might be having a problem along the same lines as thingstodo
Originally Posted by MPaulHolmes View Post
Could you do:
stream-poscnt 1
data-stream-period 100
then slowly turn the motor shaft by hand to see if you get smoothly changing position. That will show that the encoder is working properly.
I tried this but still only saw 0s. I was able to get my hands on a scope, so I hooked it up to the resolver and then encoder outputs, captures of which I've attached. From what I can tell, the encoder output seems to be fine (90deg shift between QEA-QEB, 0-5V, Index pulse every 1/4 turn, etc).
However, this was done without current sensors or throttle connected, so there were faults triggered. Are these faults preventing the "poscnt" variable from being updated/streamed properly? Or can there be another issue at play here?
ID:	24065   Click image for larger version
ID:	24066   Click image for larger version
ID:	24067   Click image for larger version
ID:	24068   Click image for larger version
The Following User Says Thank You to wootwootman For This Useful Post:
MPaulHolmes (05-01-2018)
