planning to see cars
I'll be traveling to look at 2006 and 2009 Prius' in a couple of days.
What should my process be to inspect them, and what all should I check for?
My plan is to look over the car first, then drive it, see how it turns, accelerates, and how the bars change. I've never been inside a Prius and don't know how the display works, nor how to check for things. After that my plan is to look under the hood, and see if there's any evidence of wear or leaking. I'm not sure how to apply load to the battery and check that. Suggestions are much appreciated. Thanks.
