Sorry, I can't tell you an exact number since I traded the vehicle last December. But I was getting 42 mpg @ 70 mph before adding lean burn.
Again, the gains from lean burn were at lower rpm, due to the higher load the Volt has due to the motor generator. So minimal gains at 70+, but substantially better at 55-ish.
2018 Chevy Volt
