Originally Posted by thingstodo
I logged the config and started logging data once per second. I ran the driven tires backward and verified that the mechanical motor speed was registering.
The I did RUN-PI-TEST. And I waited. The motor started making pulsing sounds after maybe 5 minutes. And it went on .. and on .. and on ...
Hmmm is it possible to stream data while running the test? Might be helpful in diagnosing. Otherwise I'd just hook up all the measurement equipment you've got
I connected Pin1 of the AD2S1210 back to GND and the board is back to acting like it was originally: 4 Index pulses per motor revolution. Thinking about it more, would it be possible to run the ACController code in this configuration? Would it just run at 1/4 speed, or would it require me to change the "encoder-ticks" config setting?
