Old 05-08-2018, 03:38 PM   #27 (permalink)
oil pan 4
Probably better off installing more PV and running a hot water heat pump.
Depending on your homes lay out and where you live, some where cold like MA installing solar hot water can be a real pain because you have to run glycol and run these lines where you don't normally run water lines. That means you could be tearing out walls through 1 or 2 floors in a typical new England style home if your water heater is in the basement.
Actually I would only go through the trouble of thermal solar if I was going off grid and wanted to futlrther reduce my propane bill.
Xist (05-08-2018)
