All the wheel bearing I've had to replace I could change the frequency while turning at hwy speeds, figuring out which one is a little tougher. Sure fire way is jack up one front tire, start the engine and get that tire spinning, then try the other, haven't tried with a car with TC, just replaced both since if one was the bad the other isn't that far behind. I did ebay bearings on my cobalt, 12,000 miles later had to replace it again, went with Moog after that.
