I have found a ready made tunnel tent that will fit over the combo. I'll probably back the trailer into one end of the tent, (through an enlarged door, if necessary,) then disconnect the car, pull it out, and seal the door. Entry is through the door at the other end.
https://www.walmart.com/ip/Ozark-Tra...ef&athena=true
